Forums >> Revit Building >> Technical Support >> Glazing in curtain walls
Wed, Dec 9, 2015 at 4:00:34 PM | Glazing in curtain walls
raaber
When I delete a mullion in a curtain wall and then try to remove the associated grid line nothing happens. What is the proper method to achieve the removal of the mullion and the grid line? Revit leaves two glazing panels and I cannot insert a door.
Thu, Dec 10, 2015 at 1:10:57 AM | Glazing in curtain walls
archigrafix
5 Stars: 4 Votes
Check that the curtain wall does not have a rule in the type properties to create that gridline/mullion automatically. One can set type rules on divisions of the wall horizontally and vertically.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Thu, Dec 10, 2015 at 6:50:44 AM | Glazing in curtain walls
After placement, I like to change my curtain walls to one that has no definitions at all so that I can add doors, adjust spacings etc.
Thu, Dec 10, 2015 at 7:38:15 AM | WWHub
archigrafix
5 Stars: 4 Votes
Quoting WWHub from 2015-12-10 06:50:44
I agree with that.
Marc Faber
Raking curtain walls, adding tags to Shop Front glazing
Tue, Mar 7, 2006 at 9:35:58 PM
Curtain system > glazing panel matherial
Mon, May 28, 2012 at 1:02:14 PM
Angled Curtain Walls - Not Sloping Glazing
Wed, Apr 22, 2009 at 3:20:31 AM
sloped glazing in schedule
Wed, Jun 17, 2009 at 10:18:35 AM
Rendering - curtain walls
Mon, Jun 5, 2006 at 8:04:39 AM
Page generation time: 0.3502
