Forums >> Revit Building >> Technical Support >> handrail profile not available
Tue, Dec 8, 2015 at 7:07:11 PM | handrail profile not available
KennedyDrafting
Using REVIT 2016.     Trying to create a handrail with a custom profile.     I made the profile loaded it into the project. (I tried two different templates, Profile.rft and Profile-Rail.rft) neither worked.
I can see the profile in the project browser under "Profiles".    But when edit the railing family, under Handrail 1,  the new profile is not a choice.
What obvious thing am I missing?
Thanks,
JK
Wed, Dec 9, 2015 at 7:23:23 AM | handrail profile not available
archigrafix
5 Stars: 4 Votes
Assuming that you have not purged all families i can suggest the following. See what prodiles you have available in that tool. Locate them on the family browser (they should be listed with the same name you see in the railing tool). Edit one of them by selecting it on the family browser, save as a new name. (That is to duplicate the profile family that is working) Make your new geometry in the new profileand load it into your project. You should be in theory able to locate your new profile now.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Wed, Dec 9, 2015 at 7:30:48 AM | handrail profile not available
If nobody ha messed with your template, then the railing profile will be correctly set to railing and after loading, it will show up in the profile dropdown when you define your railing.
Fri, Dec 11, 2015 at 8:21:32 PM | handrail profile not available
KennedyDrafting
Thanks for the replys.  Was skipping a step. I made profile correctly but then when directly to the railing type.  I need to make the Handrail type first and THEN use the hand rail type in the railing family.
How do you model a complex curved handrail in Revit 2011?
Wed, Aug 10, 2011 at 12:23:34 PM
Adaptive Railing with Handrails
Wed, Sep 2, 2015 at 3:13:02 PM
Handrail without Balusters
Wed, Oct 2, 2019 at 4:04:39 PM
Handrail - Wall mounted
Fri, Apr 28, 2017 at 5:35:54 PM
How can I make a parametric Profile?
Thu, Nov 11, 2010 at 11:40:59 AM
Page generation time: 0.1164
