10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> HELP! Revit 2016 Invisible walls and Elevators!
14 Posts No Rating |
As the title says, I am using Revit 2016 and am having issues with invisible walls and elevators. They are in groups and they show up when I select the groups, but they do not show up when not selected. I can't find them or delete them, but they are there... Or so Revit says. Has anyone had this happen before? How would you go about fixing it? I guess it's not a major issue, but wonder if anyone knows of a plugin or workaround that could help with these types of things happen. Attached are photos of what I am talking about
This is a problem in your process but we can't know what you did. The problem lies in yuou group definition and or placement.
Ah. Ok. This is the first time I have ever seen this happen in the 8 years I have used Revit, so I wasn't sure. So the best solution would probably be to ungroup and regroup it all
Why keep in a group at all?
Groups are good for initial placement or for something that you know will change but after placemkent, it is often better to ungroup.
Because we are still in the DD phase for this project. Land Use and DD are all merging together because of how slow this city is with getting back to us. We haven't even come close to finishing the designs of the units
2010:.....invisible walls? student here.. |
Wed, Sep 16, 2009 at 7:01:00 PM
11
Ways to show corrugate walls (Revit 2016). |
Mon, Jun 14, 2021 at 2:00:33 AM
Massing appears when exporting from revit 2016 to navisworks 2016 |
Tue, Feb 2, 2016 at 11:28:30 AM
Invisible Hatching on Toposurface |
Sat, May 26, 2018 at 6:24:44 AM
Rendering an invisible wall. |
Sun, Apr 24, 2011 at 12:01:49 PM
