Forums >> Workflow & Implementation >> Hardware >> 20 building in Revit, now it's lagging, any solution? Different software?
Tue, Dec 8, 2015 at 8:27:24 AM | 20 building in Revit, now it's lagging, any solution? Different software?
lolcocks
Hi, I made a 3D model of my Village in Revit with 20 buildings as links.Now the problem is that after loading these links Revit lags a lot.My system configuration is 32 GB RAM, 4.00 GHz Octa Processor, Nvidia Quadro K620.Now with the file running in the baground hardly any of my resources are being used.
Max is 5 GB RAM, 800 MB in the graphic card and processor is used around 30%.
The project is on an SSD and even it's not being used.
How do I reduce this lag? Is a different software recommended for such large scale projects?I plan on working on smart cities as well. What software should I use for that? Is Revit sufficient because a smart city will have many more buildings and then Revit will lag like crazy.What do I do?
Tue, Dec 8, 2015 at 8:39:19 AM | 20 building in Revit, now it's lagging, any solution? Different software?
We don't know enough about your projects to really answer your question.  So much depends on how you modeled them and what is included.
Trees, plantings and entourage can really bog down a model.  Also, interior objects. If you used families tghat are so heavy because the creators modeled items like nuts and bolts or hidden components then that too is problematic.
I insist in our office that the exterior of the building, walls, fllors, roof, windows and doors are all put on a shell workset and I turn off all interior worksets for exterior views.  We also place each link in a seperate workset that can be turned off or unloaded for faster control when working in a specific area.
Tue, Dec 8, 2015 at 2:48:58 PM | 20 building in Revit, now it's lagging, any solution? Different software?
archigrafix
5 Stars: 4 Votes
You could test the 3d Section Box to identify if there is a particular are of your project that is causing that delay.
Are you working in the metric system or in imperial? Revit works natively in imperial system so if you have a lot of objects in the metric system, and at a significant distance from the origin I suspect that it will do a lot of extra calculations.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Tue, Jan 19, 2016 at 9:57:08 AM | 20 building in Revit, now it's lagging, any solution? Different software?
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
If you can survive, try using and turning off worksets for building elements and/or just go to visibility graphics and turn off anything not necessary for your views.  Set up some templates to be used later.
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Autodesk Sustainable Building Design Software
Mon, Feb 14, 2011 at 1:54:10 PM
Is Archvision the only software for RPC's?
Wed, Apr 18, 2007 at 10:58:38 AM
Revit is being held back by Autodesk's desire to sell other software, IMVHO.
Mon, Nov 13, 2006 at 11:54:50 PM
How much revit is better than other building design and drawings software?
Thu, Jun 28, 2012 at 12:35:29 PM
Best Software for Modular houses?
Thu, May 13, 2010 at 9:30:01 AM
Page generation time: 1.4980
