Forums >> Revit Structure >> Technical Support >> Objects on a Filter
Sun, Dec 6, 2015 at 5:28:38 PM | Objects on a Filter
seira470
Hey all,
Is there any way that you can select an object and be able to see if it has been placed on a filter and if so the name of the filter(s)?
The only way I know how is to go into a 3D view of the model and to turn on/off the filters in the visibility graphics and then see which items show in the 3D model. It's ok but find it a bit time consuming especially if you're not familiar with the setup of a project.
Any thoughts?
Cheers!
Mon, Dec 7, 2015 at 7:26:15 AM | Objects on a Filter
Sorry, you can only look at the filterrs.
selection filter
Sun, May 21, 2006 at 9:32:56 PM
Filtering objects that do not have their category listed in the Filters Setup...
Wed, Nov 4, 2009 at 11:17:38 AM
Filter turns everything off
Wed, Apr 19, 2017 at 9:25:54 AM
show 3 levels at the same time
Wed, Feb 23, 2011 at 9:12:01 AM
linework tool
Thu, Mar 6, 2008 at 9:23:06 AM
Page generation time: 0.1329
