Forums >> Revit Building >> Technical Support >> Phase "new" in plan: doors cut pattern same as wall
Sat, Dec 5, 2015 at 6:00:00 AM | Phase "new" in plan: doors cut pattern same as wall
Splendid2
How can I get rid of displaying hatch in doors, pls see IMG New construction phase, New doors in New wall has same hatch. So Dooors in plan looks like a wallSad help
Sun, Dec 6, 2015 at 7:10:10 AM | Phase "new" in plan: doors cut pattern same as wall
archigrafix
5 Stars: 4 Votes
You can override the doors with a solid white hatch in the cut setting for instance, in the view template, or directly overriding each door.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Tue, Dec 8, 2015 at 5:19:32 AM | Phase "new" in plan: doors cut pattern same as wall
Splendid2
thanks!
Tue, Dec 8, 2015 at 7:40:25 AM | Phase "new" in plan: doors cut pattern same as wall
Instead, change the material for the door panel to one that does not have a cut hatch pattern defined.
Elements not being hosted after pasting "at same location" (2010)
Tue, Nov 24, 2009 at 3:10:11 PM
Copying doors from one phase to another
Thu, Feb 7, 2008 at 2:29:40 PM
Cut pattern under graded region or slabs not showing in plan [ 1 2 ]
Tue, Jul 22, 2008 at 5:13:50 PM
18
Curtain wall doors wont center up
Mon, Oct 12, 2009 at 4:28:48 PM
Maintaining "Phase Demolished" properties.
Thu, Jun 18, 2015 at 8:19:39 AM
Page generation time: 1.4173
