Forums >> Revit Building >> Technical Support >> Mass Geometry Flaw | Circle points
Fri, Dec 4, 2015 at 3:56:10 PM | Mass Geometry Flaw | Circle points
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
So I've discovered in the conceptual mass environment that Revit appears to be unable to create an arc from curve points on a circle. I've created a circle from reference lines and then created two reference points hosted to that circle. What is not possible to a) create an arc between those two points!!!!! And b)create another circle from the same origin, slice and lock sliced points to the curve points of the underlying circle!!!! Why for the love of Autodesk, is this not possible?!! It is totally f'ing up a mass I'm trying to create. Please help me understand if I'm missing something. Thanks.
Fri, Dec 4, 2015 at 4:04:46 PM | Mass Geometry Flaw | Circle points
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
....it would not be possible if 3D snapping inadvertantly was unchecked when attempting!!! AHHHHHH! Bad Cody...don't do that. Thanks.
How can I reference lines/circles/geometry in my model from a component?
Thu, Nov 19, 2015 at 12:30:29 PM
Adding fillet to circle mass
Tue, Jun 5, 2012 at 6:29:31 AM
Mid-Point between two objects?
Thu, Oct 4, 2007 at 7:35:16 AM
Help with Geometry
Sun, Dec 20, 2009 at 5:19:54 PM
adding control points on a mass model
Fri, Oct 15, 2010 at 11:08:17 PM
Page generation time: 1.4827
