Forums >> Revit Building >> Technical Support >> Use .rte object in my .rvt
Fri, Dec 4, 2015 at 12:04:10 PM | Use .rte object in my .rvt
EricjamesD
Hi guys, I recently downloaded a BIM that is a .rte file of a garden roof: http://resources.hydrotechusa.com/resources.php?category=BIM it's the garden roof assembly intensive file
So, basicly I have no idea how to use it in my project. Can I convert it into a rfa file and use it as a roof.
I'm using Revit 2015 with latest updates.
Fri, Dec 4, 2015 at 12:44:24 PM | Use .rte object in my .rvt
marmiketin1
4.5 Stars: 10 Votes
all you need to do is to open up the rte file that has the roof type in it. it already has a roof sample drawn in the file so just select it and copy it. then open up the project you want to use the new roof family in and paste it in. it will bring over the roof family type which you can now use for any roof. it will also bring over any of the materials and fill patterns that are used.
RTE vs RVT
Thu, Sep 26, 2019 at 9:21:04 PM
Revit Template File from Project file .rvt to .rte
Sun, Apr 28, 2013 at 1:35:39 AM
.Rte - View Template Settings - Reset Linked .Rvt Graphic Overrides
Tue, Feb 10, 2009 at 2:19:03 PM
Cannot get the Mechanical-Default_Metric.rte template to load
Sat, Jun 9, 2012 at 2:30:21 AM
save as from template to rvt
Wed, Feb 15, 2012 at 6:31:16 PM
Page generation time: 1.3012
