32 Users Online (30 Members):
Forums >> Revit Building >> Technical Support >> Uin note block
19 Posts No Rating |
I'm in the process of converting standard construction notes from AutoCAD to Note Block in REVIT. When I copy and past the Mtext from AutoCAD, the line break characters are also copied into the note block, but the margin is not working exactly in the same way as AutoCAD. I can delete the line break portion pasted from AutoCAD inside note block but I cannot see what the line break character is. If I wants to introduce a specifice line break inside the paragraph text of the note block, what special character sequence shoul I enter?
Thanks in advance for your comments and assistance. :-)
Hi Paul
I suggest copy from Mtext, into NOTEPAD and remove all extra 'enter's and 'tabs', then copy a clean version of the text into your Revit noteblock, see if that helps.
There are no formatting characters that you can use in Revit. It excepts hard returns and tabs.
How do I Edit the Apperence of a Note Block |
Mon, Jan 12, 2009 at 1:44:04 PM
Revit 2015 - Filter Note Block Keynotes by Those Visible on a Sheet |
Sun, Mar 4, 2018 at 2:08:58 PM
Note Block / Schedule for General Construction Notes |
Wed, Feb 25, 2009 at 10:45:50 AM
Text Notes Paragraph Formatting (numbered) |
Mon, Oct 21, 2013 at 10:41:17 AM
Window and Door schedule with note blocks? |
Tue, Jul 11, 2023 at 2:50:46 PM
