Forums >> General Discussion >> Revit Project Management >> Separate drawing sets
Tue, Dec 1, 2015 at 11:14:04 AM | Separate drawing sets
paudy86
Hi,
I am trying to figure out the best work flow for creating separate drawing sets in a project.
Basically we have a project with two different drawing packages. The main drawing package includes all of our drawings but the Planning drawing set only icludes about half of the drawings. The drawings in the Planning Set are identical to the main set apart from the fact that we cant have any view references showing that refer to drawings not being submitted.
Duplicating the views could be problematic as we would need to remember to update both views whenever we change annotation, visibility graphics etc. Duplicating as dependent means would mean we would have to keep track of which view references are turned on or off.
Is it possible to put view references on their own workset?
I'd be interested to know how other people approach this.
Thanks,
P
Tue, Dec 1, 2015 at 12:22:23 PM | Separate drawing sets
All annotations are on the view workset and can not be changed.
You can use view filters.
Tue, Dec 1, 2015 at 1:44:15 PM | Separate drawing sets
paudy86
Seems like adding view references to filter cannot be done either.
It looks like the only answer is to use some convoluted, error-prone work around.
Revit 2016 - Multiple Drawing Sets in Sheet Index
Fri, Jan 12, 2018 at 10:38:33 AM
Wed, Jun 24, 2015 at 6:11:13 PM
Option Sets displayed together?
Wed, Apr 2, 2008 at 9:36:13 AM
Drawing sets
Wed, Apr 15, 2015 at 5:11:04 PM
SUB SETS UNDER A LINKED MODEL
Tue, Jun 19, 2018 at 9:31:39 AM
Page generation time: 0.2213
