Forums >> Revit Building >> Technical Support >> 2' Staggered 6'x18" panels
Tue, Dec 1, 2015 at 10:43:42 AM | 2' Staggered 6'x18" panels
kbendle585
Hey guys,
I have a .pat file problem. I want 6'x18" panels to be staggered 2' from one to another. Currently I have the panel size correct, but the panel's are centered to eachother line to line (staggered 3', not 2'). Please Help!
*6'x18" Staggered Panel,
;%TYPE=MODEL,
0 , 0 , 0 , 0 , 18
90 , 0 , 0 , 18 , 36 , 18 , -18
Thanks!
Kyle
Tue, Dec 1, 2015 at 2:07:14 PM | 2' Staggered 6'x18" panels
marmiketin1
4.5 Stars: 10 Votes
Is this what you are looking for?
;%TYPE=MODEL,
0 , 0 , 0 , 0 , 18
90 , 0 , 0 , 18 , 24 , 18 , -36
Tue, Dec 1, 2015 at 2:09:36 PM | 2' Staggered 6'x18" panels
marmiketin1
4.5 Stars: 10 Votes
;%TYPE=MODEL,
0 , 0 , 0 , 0 , 18
Tue, Dec 1, 2015 at 4:17:01 PM | 2' Staggered 6'x18" panels
kbendle585
Yes! That is it. Of course I figured it out right before you replied, but thank you. I'm slowly understanding these .pat's.
Wed, Dec 2, 2015 at 7:27:37 AM | 2' Staggered 6'x18" panels
marmiketin1
4.5 Stars: 10 Votes
It can be a little bit tricky at the beginning when learning.
Some tips to know are that there is a limit on how large of numbers you can use. I think it is around 1000 so you want to make sure any patterns you create, the lines repeat at a distance less than that.
Also the shift x,y plane rotates with the angle but the origin plane does not.
Here is one of the more tricky patterns I just made recently. I drew it in autocad first so I could measure my distances and figure out offsets and penup/pendown lengths.
*36in Star,
;%TYPE=MODEL
0,           1,0,                18,18,              34,-2
0,           -1,-1,              18,18,              2,-34
0,           -1,1,               18,18,              2,-34
90,          0,1,                18,18,              34,-2
90,          -1,-1,              18,18,              2,-34
90,          1,-1,               18,18,              2,-34
45,          1,1,                0,25.4558,          22.6274,-2.8284
-45,         1,-1,               0,25.4558,          22.6274,-2.8284
18.4349,     4.5,-4.5,           22.7684,11.3842,    28.4605,-28.4605
18.4349,     3.8667,6.4,         22.7684,11.3842,    4.0056,-52.9154
18.4349,     10.3333,10.3333,    22.7684,11.3842,    4.0056,-52.9154
-18.4349,    4.5,4.5,            -22.7684,11.3842,   28.4605,-28.4605
-18.4349,    -7.6667,7.6667,     -22.7684,11.3842,   4.0056,-52.9154
-18.4349,    -14.1333,11.6,      -22.7684,11.3842,   4.0056,-52.9154
71.5651,     -4.5,4.5,           -22.7684,11.3842,   28.4605,-28.4605
71.5651,     6.4,3.8667,         -22.7684,11.3842,   4.0056,-52.9154
71.5651,     10.3333,10.3333,    -22.7684,11.3842,   4.0056,-52.9154
-71.5651,    -4.5,-4.5,          22.7684,11.3842,    28.4605,-28.4605
-71.5651,    6.4,-3.8667,        22.7684,11.3842,    4.0056,-52.9154
-71.5651,    10.3333,-10.3333,   22.7684,11.3842,    4.0056,-52.9154
*72in Star,
;%TYPE=MODEL
0,           2,0,                36,36,              68,-4
0,           -2,-2,              36,36,              4,-68
0,           -2,2,               36,36,              4,-68
90,          0,2,                36,36,              68,-4
90,          -2,-2,              36,36,              4,-68
90,          2,-2,               36,36,              4,-68
45,          2,2,                0,50.9116,          45.2548,-5.6568
-45,         2,-2,               0,50.9116,          45.2548,-5.6568
18.4349,     9,-9,               45.5368,22.7684,    56.921,-56.921
18.4349,     7.7334,12.8,        45.5368,22.7684,    8.0112,-105.8308
18.4349,     20.6666,20.6666,    45.5368,22.7684,    8.0112,-105.8308
-18.4349,    9,9,                -45.5368,22.7684,   56.921,-56.921
-18.4349,    -15.3334,15.3334,   -45.5368,22.7684,   8.0112,-105.8308
-18.4349,    -28.2666,23.2,      -45.5368,22.7684,   8.0112,-105.8308
71.5651,     -9,9,               -45.5368,22.7684,   56.921,-56.921
71.5651,     12.8,7.7334,        -45.5368,22.7684,   8.0112,-105.8308
71.5651,     20.6666,20.6666,    -45.5368,22.7684,   8.0112,-105.8308
-71.5651,    -9,-9,              45.5368,22.7684,    56.921,-56.921
-71.5651,    12.8,-7.7334,       45.5368,22.7684,    8.0112,-105.8308
-71.5651,    20.6666,-20.6666,   45.5368,22.7684,    8.0112,-105.8308
Wed, Dec 2, 2015 at 8:20:23 PM | 2' Staggered 6'x18" panels
hugh
3.5 Stars: 4 Votes
There is no meaningful upper limit on pattern size when loading a pattern using the HatchKit Add-In for Revit in conjunction with HatchKit - the upper limit exists only within Revit's Fill Patterns manager.
Hugh Adamson
www.hatchkit.com.au
Thu, Dec 3, 2015 at 12:56:54 PM | 2' Staggered 6'x18" panels
kbendle585
Wow... that is a complicated pattern! Nicely done.
Thanks for the help guys. I've played with a few different patterns now and I understand it all much better. I will grab that plug-in but I really wanted to really understand how it works first.
Thanks again!
Staggered tile PAT file needed: 96" W x 21" H
Tue, May 20, 2014 at 3:19:02 PM
Need help with a Staggered/ Running bond pattern with angles
Wed, Jun 23, 2010 at 11:54:57 PM
Change 0'-0" MAIN LEVEL to 100'-0"
Tue, Aug 22, 2006 at 7:40:49 PM
I need to change my building levels from 0'-0" to 100'-0"
Sat, Sep 11, 2010 at 8:03:55 PM
12
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Page generation time: 2.9675
