Forums >> Revit Building >> Technical Support >> Wall to be automatically stop below concrete beam
Mon, Nov 30, 2015 at 8:04:40 PM | Wall to be automatically stop below concrete beam
ricardolion
Dear all,
I'm new to revit and had trouble doing the section , tried searching it on google but no result..
Is there any way to stop this (image attached) wall to collide with the beam? I wanter the wall to be automatically stop below the beam..
Also, when I export my plan to dwg, there is always column missing randomly.. Had checked the problem but it seems all column have the exact same properties as the column which appear when I export to CAD.. any insight?
Mon, Nov 30, 2015 at 9:02:20 PM | Wall to be automatically stop below concrete beam
ricardolion
Hm,just tried join and worked..
Still did not find the clue for the missing column when export to dwg
Wed, Dec 2, 2015 at 8:58:50 AM | Wall to be automatically stop below concrete beam
marmiketin1
4.5 Stars: 10 Votes
you can use the align tool. which is under the modify tab.
In section if you use align and then click the underside of the concrete beam and then the top of the wall it will line the wall up to the bottom of the beam.
Beam end element control
Tue, Nov 5, 2013 at 12:54:56 PM
curved concrete beam
Fri, Oct 17, 2008 at 6:10:21 PM
concrete beam on top of inclined wall
Wed, Jun 20, 2007 at 11:09:17 AM
Beam connection to a concrete wall
Thu, Sep 13, 2012 at 12:40:52 PM
13
beam finishes
Wed, Sep 19, 2012 at 3:11:30 PM
Page generation time: 2.1616
