Forums >> Revit Structure >> Technical Support >> Foundation Top of Footing (when Level is something other than 0'-0")
Mon, Nov 30, 2015 at 7:54:52 AM | Foundation Top of Footing (when Level is something other than 0'-0")
RevitRural
I want my foundation Tag to read -8", -3'-4", etc. (top of elevation, from level)
When the level is set to 0'-0", it works as desired.
If the level is set to something other than 0'-0", it does not.
What am I missing?
Mon, Nov 30, 2015 at 7:58:48 AM | Foundation Top of Footing (when Level is something other than 0'-0")
RevitRural
Also/or
Is there a way to get the "offset" parameter to be part of a Foundation Tag? I know Structural Framing Tags allow you to read the "z-offset". This would also solve my issue if it can be done.
Thanks.
Wed, Dec 2, 2015 at 11:07:12 AM | Foundation Top of Footing (when Level is something other than 0'-0")
marmiketin1
4.5 Stars: 10 Votes
your best bet is to create another level line at the top of your footing and then have the footing associated with that level instead of the 0'-0" level it is currently associated with. then you do not need to offset the footing at all and you can adjust the footing level however you like.
Wed, Dec 2, 2015 at 2:03:03 PM | marmiketin1
RevitRural
edit-deleted
Edited on: Wed, Dec 2, 2015 at 2:04:02 PM
Edited on: Wed, Dec 2, 2015 at 2:05:02 PM
Edited on: Wed, Dec 2, 2015 at 2:07:03 PM
Wed, Dec 2, 2015 at 2:06:17 PM | Foundation Top of Footing (when Level is something other than 0'-0")
RevitRural
  If I were doing a shed that would be okay, but we have dozens of different footing elevations in a given project. They all need to be taken from floor level, which is usually a MSL elevation.
Thanks for the response though.
Due to the lack of responses I assume this can't be done. Typical Revit.
Wed, Dec 2, 2015 at 2:27:38 PM | Foundation Top of Footing (when Level is something other than 0'-0")
We don't know what tag you are using but almost all tags that read offsets can be set to relative to the current level or to the project elevation.  EDIT your tag.
Wed, Dec 2, 2015 at 2:42:58 PM | Foundation Top of Footing (when Level is something other than 0'-0")
RevitRural
My tag is a Structural Foundation Tag that reads "Elevation at Top".
The current project I am working with has the main floor elevation as 1,697.00'. Whenever I use the tag for a footing 4'-0" below floor elev. it displays "1,693.00'" instead of -4'-0" that I would prefer.
It's just more confusing for everyone, contractor included, especially when you get into feet and INCHES.
Wed, Dec 2, 2015 at 3:23:31 PM | Foundation Top of Footing (when Level is something other than 0'-0")
I'm an architect so excuse me for being a little slow here...  No comments.
All spot elevations can be set to read actual elevation or relative and when they are placed, you can pick what they are relative to.  I thought the foundation tag with elevation would act the same but it does not seem to.
My structural foundation tag reads from level one (negative as you want it to)... and I can't set it to read as yours does so I am missing seeing a switch somewhere.
Wed, Dec 2, 2015 at 4:00:54 PM | Foundation Top of Footing (when Level is something other than 0'-0")
Reading elsewhere, I see that others are using the spot elevation tag which will work for you.  You can add prefix or suffix like AFF
Wed, Dec 2, 2015 at 4:05:29 PM | Foundation Top of Footing (when Level is something other than 0'-0")
RevitRural
lol @ "a little slow". You're likely the most knowledgeable person here.
Here's my project.
My "grade beam" is set as "structural framing" so there is a "z-offset", which I can use in my 'structural framing tag'. This gives me the nice -8" number I desire.
The "footing" in the pic is set as "structural foundation" and thus there is no z-offset, but there is an "offset" property. However there is no way to tag this in the 'structural foundation tag' (that I am aware of).  I'm having to use the "elevation at top" field, and it tends to display the actual elevation (much like a spot elevation I imagine.)
Wed, Dec 2, 2015 at 4:07:29 PM | Foundation Top of Footing (when Level is something other than 0'-0")
RevitRural
Okay thanks. I will look into the spot elevation tag you mentioned.
Fri, Jan 29, 2016 at 1:40:13 PM | Foundation Top of Footing (when Level is something other than 0'-0")
iamian33
iamian33 Avatar
I wanted to check and see if anyone has found a way to modify the Foundation Tag so that our structural team can simply tag (type mark and Elev at Bot) the footings and not have to use a tag AND spot elevation for each footing?
Ian Shafer
Principal Consultant
True North S&F Consultants
Strip Footing not wanted in Foundation schedule
Mon, Mar 28, 2016 at 4:05:52 PM
Visibility of foundation wall and spread footing in architectural views
Sat, Apr 19, 2008 at 8:24:00 PM
Slab Foundation
Thu, Jan 31, 2008 at 1:59:46 PM
Wall Constraints
Mon, Jul 9, 2007 at 9:26:53 AM
Foundation Plan Help
Sun, Feb 28, 2010 at 9:00:27 AM
Page generation time: 1.4562
