Forums >> Revit Systems >> Technical Support >> Audit central file - it's giving error
Sat, Nov 28, 2015 at 1:30:54 PM | Audit central file - it's giving error
marwan123
I wanted to audit the central file. when i click the audit and central file after click open; audit is starting after short time it's giving the message "An unrecoverable error has occurred.  The program will now be terminated.  All of your data has been recently saved, so there is no need to create recovery files" after revit is closing. I detach the central file and save as again and enable worksets again. I tried to audit situation is same.It’s giving same error. Please can you help me? how can i resolve it?
Sat, Nov 28, 2015 at 3:10:32 PM | Audit central file - it's giving error
It sounds like your file has a serious problem.  If you are on subscription, then send it to autodesk.  Oterwise, you may have to fall back on an earlier backup.
Sat, Nov 28, 2015 at 11:21:30 PM | Audit central file - it's giving error
marwan123
is there any method to resove this audit problem? when i audit the central file; I see percentage from below ; processing is ok after when the uploading reference it's giving error. It can be related with autocad links or revit links?
if i can't resolve i will use earliest back up. But i will lose approximatelly 1 day work which we did on saturday
I didn't use back up file of central file before, can you assist me please. How i will use it? just change the name of back up file as rvt? or there is important rules to use back up file of central file?
Edited on: Sat, Nov 28, 2015 at 11:24:00 PM
Mon, Nov 30, 2015 at 9:43:50 AM | Audit central file - it's giving error
Pikachu123
Just go to the Collaborate tab > CLcik "Restore Backup" > then navigae to the central file, and open the "(central file name)_backup" folder *Note* there will not be an actual file visible in the window > After you click "Open" a window will pop-up within revit with a list of backups accompanied with dates to choose fom.
Killing error while saving file to central
Mon, Aug 18, 2008 at 1:58:13 PM
Error - Local File Resides in Central File Location
Fri, Apr 9, 2010 at 8:34:55 AM
Renaming of the Architect's Central File
Tue, Dec 29, 2009 at 7:13:54 PM
Worksets/Central files
Tue, Jul 24, 2007 at 2:26:31 PM
Can not create local file from Central
Tue, Mar 6, 2012 at 11:57:26 AM
Page generation time: 6.6597
