Forums >> Revit Building >> Technical Support >> Cannot cut into only one floor
Wed, Nov 25, 2015 at 5:03:09 PM | Cannot cut into only one floor
Jake1108
Hi there,
I am modelling my own domestic residence for a university project and seem to have hit somewhat of a roadblock. I am trying to cut into the floor of my second level in order to make way for the entrance to the staircase. As you can see in the second picture I have done this successfully for the floor above.
The problem is when I try to select the floor there is some sort of error, it does not show one but the floor does not become transparent It becomes slightly blue but still brings up the correct options for editing the floor. I can therefore not see the correct size of the cut needed because the stairs below are hidden behind the floor.
I have tried disregarding this and making the cut anyway but, as you can see in the third picture it simply comes up as a thin black line and no cut is made.
Both floor types are exactly the same and I have tried deleting and replacing the floor but the same thing happens.
Anyone have any idea as to the source of this problem and how to fix it?
Wed, Nov 25, 2015 at 6:37:41 PM | Cannot cut into only one floor
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
It looks like you have two floors in the same place. Delete one.
how to see through floor cut opening on plans?
Thu, Nov 18, 2010 at 10:02:14 PM
Roof-based family is not cut in floor plan?
Mon, Sep 13, 2010 at 9:08:48 AM
Cut floor around walls
Fri, May 24, 2013 at 12:09:36 PM
Floors not being cut in sections in 2013
Fri, Jan 11, 2013 at 8:44:07 AM
cutting a hole in a massed floor/roof
Mon, May 11, 2009 at 7:07:00 AM
Page generation time: 0.4103
