Forums >> Revit Building >> Technical Support >> Overzealous Cornering (Revit LT 2014)
Tue, Nov 24, 2015 at 12:46:52 PM | Overzealous Cornering (Revit LT 2014)
kittyj2345
In the attached screenshot1, you can see that we have two stairs going down from a basement to a garage. Since the stair extends further into the basement than the adjacent walls, I need to add a small wall under the floor on either side of the top step to hold back the earth under the basement floor.
However, when I add this small wall, it automatically joins with the adjacent wall by extending into its core, which I don't want. See how it's joining in screenshot2. I tried using the corner tool to cycle through different joining options, but it doesn't give me the option that I want: the larger wall on the left having a continuous plane down to the stair, and the small wall meeting that plane.
Any ideas?
Tue, Nov 24, 2015 at 1:32:00 PM | Overzealous Cornering (Revit LT 2014)
On all walls, you have a blue button the end where you can pick to turn off/on wall join.
Tue, Nov 24, 2015 at 1:51:57 PM | Overzealous Cornering (Revit LT 2014)
kittyj2345
Hm... I see blue grips at either end of the wall. If I click them, nothing happens. If I drag the one at the edge I'm trying to edit, it moves back to where it is.
Is there a different blue button I'm missing?
Tue, Nov 24, 2015 at 2:48:19 PM | Overzealous Cornering (Revit LT 2014)
Right click on the dot.
Tue, Nov 24, 2015 at 3:49:05 PM | Overzealous Cornering (Revit LT 2014)
kittyj2345
Perfect! Thank you.
Wall cornering ABOVE wall vs wall cornering cut THROUGH wall
Fri, Feb 1, 2013 at 8:11:19 AM
How to import sketchup models into revit 2014
Fri, Aug 5, 2016 at 9:29:15 AM
RevitRubyShell Revit 2014
Fri, Jun 7, 2013 at 7:10:05 AM
Opening a 2015 drawing in Revit 2014
Tue, Jul 29, 2014 at 9:11:58 AM
Revit 2014 upgrade issue - in place families appearing black?
Fri, Jun 21, 2013 at 10:58:41 AM
Page generation time: 2.9259
