Forums >> Revit Building >> Technical Support >> Pattern - Running Bond
Mon, Nov 23, 2015 at 12:17:44 PM | Pattern - Running Bond
benlink
I'm basically trying to creat a larger running bond pattern.  I started by copying the 8 x 16 CMU text in the .pat file and changed the numbers to what I thought would get the larger spacing:
*Clap Board 18x72,  18 x 72 blocks running bond
;%TYPE=MODEL
0,             0,             0,             0,             18
90,            0,             0,             36,             36,             36,             -36
However, my results are not what I'm looking for.  See attached.  What am I doing wrong?
I've read over the instructions at the top, but I suppose I'm completely missing something.  Thanks.
I'm in 2015.
Mon, Nov 23, 2015 at 1:08:50 PM | Pattern - Running Bond
Your first 36 in the second row needs to be 18
Mon, Nov 23, 2015 at 1:35:34 PM | Pattern - Running Bond
benlink
I had thought that too, but it winds up with the attached pattern.
I'm trying to get 18" in height for horizontal lines, by 72" spacing of vertical lines.
See attached.
Mon, Nov 23, 2015 at 1:36:40 PM | Pattern - Running Bond
benlink
This being the pattern:
;%TYPE=MODEL
0,             0,             0,             0,             18
90,            0,             0,             18,            36,             36,             -36
Mon, Nov 23, 2015 at 2:28:23 PM | Pattern - Running Bond
Sorry ... I missed this
0,             0,             0,             0,             18
90,            0,             0,             18,             36,             18,             -18
Mon, Nov 23, 2015 at 3:39:36 PM | Pattern - Running Bond
benlink
Ah!
I need to study how these work more.
Thanks.
Tue, Dec 1, 2015 at 2:29:45 PM | Pattern - Running Bond
marmiketin1
4.5 Stars: 10 Votes
The biggest tip for anyone trying to get started in patterns is that the x,y planes for the origin values are locked but the x,y planes for the shift values rotates with the angle.
You can test this by simply changing the 5th numbers, in the 0 degree row the 5th number shifts the horizontal lines up or down but in the 90 degree row the 5th number shifts the vertical lines left and right. This seems odd as both values are y-shifts but it is very useful when dealing with complex patterns that have many different angled lines.
Tue, Dec 1, 2015 at 3:18:32 PM | Pattern - Running Bond
benlink
Thannks for the info, marmiketin1.
Custom Running Bond Brick Pattern
Fri, Aug 26, 2016 at 2:38:25 PM
4’ x 8’ running bond hatch.
Thu, May 8, 2008 at 7:02:50 AM
Vertical Reveals for Running Bond Pattern
Thu, Sep 3, 2009 at 8:20:46 AM
Curtain Wall runnning bond pattern
Fri, Nov 4, 2011 at 11:34:18 PM
Need help with a Staggered/ Running bond pattern with angles
Wed, Jun 23, 2010 at 11:54:57 PM
Page generation time: 0.1811
