Forums >> Revit Building >> Technical Support >> URGENT HELP! Rhino polysurface to Revit Mass
Fri, Nov 20, 2015 at 11:27:53 PM | URGENT HELP! Rhino polysurface to Revit Mass
yeowyh
I have modeled a polysurface in rhino and exported as .sat file.
But the problem is when i import it into revit, error being "Some ACIS objects could not be imported. To import them, use AutoCAD to convert them into polymesh objects and reimport."
And I would like to know how could I make a surface/mesh from Rhino into a mass in Revit (where I can explode and divide surface on the mass form)
Attached herewith is the .sat file.. missing part in the revit, you can see full if open in autocad.
hope someone can shed me some light.. Thanks a million.
Rhino imported as mass
Tue, May 7, 2013 at 12:58:00 AM
Rhino to Revit Conceptual Mass
Tue, Sep 10, 2013 at 8:15:45 AM
Import Rhino model into Revit
Mon, Mar 3, 2014 at 7:42:36 AM
Editing revit file in rhino.
Thu, Feb 13, 2020 at 5:19:48 AM
Revit to Rhino
Thu, Feb 13, 2020 at 5:22:39 AM
Page generation time: 3.7199
