Forums >> Revit Building >> Technical Support >> Floor Plan
Thu, Nov 19, 2015 at 8:58:34 PM | Floor Plan
kttibbs1
I'm working on a kitchen that is demolishing a wall and pushing it back 5 feet which will be an addition. My question is, on my sheet(s), do I need to show existing, demolish and completed plan? Should I put them all on one sheet? Or should I do a floor plan sheet with all 3 existing, demolish and completed and another sheet with all 3 showing sections?
Or should I just show existing and addition/completed that indicated where the demolished wall is?
Fri, Nov 20, 2015 at 12:37:57 AM | Floor Plan
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
It's personal preference really but the easiest solution is to draw a large scale plan so you have plenty of room for notes. And show the design as it will look in its final , completed state. Then on top of this show dashed lines to indicate what walls are being demolished along with detail notes to explain what is being kept, what is being retained and what is new. Cutting a section and doing the same will be needed too.
Fri, Nov 20, 2015 at 10:42:07 PM | Floor Plan
mansell5
3.5 Stars: 4 Votes
is the wall to be demolished load bearing?.
if so what will support the ceiling and roof frame over once the wall is removed?.
need a lintel sized up to span across the opening.
Sat, Nov 28, 2015 at 9:55:57 AM | Floor Plan
kttibbs1
No it's not load bearing.
I SEE 1ST FLOOR FROM 2ND FLOOR PLAN...WHY IS THAT?
Tue, May 29, 2007 at 1:33:49 PM
Elevation Level Marker Associated To Wrong Floor Plan
Wed, Feb 25, 2015 at 10:44:23 AM
Window from floor above showing on ground floor plan
Mon, Oct 10, 2016 at 7:13:10 AM
Floor Plan associated to wrong level...
Fri, Jul 2, 2021 at 3:23:05 PM
PLAN REGION VIEW DEPTH CHANGE OVERALL FLOOR PLAN
Fri, Aug 29, 2014 at 1:27:29 PM
Page generation time: 0.4907
