Forums >> Revit Building >> Technical Support >> Filled Region Sketch Mode
Tue, Nov 17, 2015 at 11:46:50 AM | Filled Region Sketch Mode
Joetaba
I'm curious if others have a display issue I've just noticed, but is also present on other machines and files we've opened. Using Revit 2015.
When in sketch mode for a filled region whether its medium lines, or heavy lines (anything heavier than 1) the sketch mode displays the line thinner than it actually is. It doesn't seem to happen if your view scale is set to 1/8", but anything larger than this and this 'glitch' shows up. For the most part its not an issue, I just go back to sketch mode and select a thinner line.
Thin Lines is of course not enabled. I was creating a filled region with wide lines and the width was just about right, but after clicking the arrow to accept the changes and exit sketch mode the lines became a little wider.
Has anyone else noticed this, maybe our hardware/videocard and display?
Tue, Nov 17, 2015 at 1:28:34 PM | Filled Region Sketch Mode
Pitufo067
I have noticed the same event previously. Revit seems to regenerate the line weight once the sketch is done. As you mention, it really shouldn't be a problem but if someone is looking for a very specific weigth they may have to go back to sketch mode in order to get what the line thickness they want.
Question about sketch Mode
Thu, Jan 17, 2013 at 6:34:56 PM
Fatal error when in any type of sketch mode
Wed, May 16, 2018 at 11:28:43 AM
Filled region not showing in elevation realistic mode
Wed, May 15, 2013 at 1:55:02 AM
Line tool shortcut when in a masking/filled region..
Mon, Feb 14, 2011 at 4:00:46 AM
Model Lines to Detail Lines???
Tue, Jul 29, 2008 at 3:01:51 AM
Page generation time: 0.3678
