Forums >> Revit Building >> Technical Support >> Dimension Glitch?
Tue, Nov 17, 2015 at 11:09:19 AM | Dimension Glitch?
FazioGreg
Has anyone else found this issue?  I came back to a dimensioned plan after making some design revisions, and parts of the dimension strings don't show.  I've attached an image that shows the string that's missing.  I can only explain it as a glitch.  If I make a new string, everything shows up.  Anyone have some insight?
Tue, Nov 17, 2015 at 11:42:33 AM | Dimension Glitch?
Pitufo067
It may help to know what kind of revisions you might have made to that wall (or whatever the witness/dimension line is attached to). The only times I notice this happening is when the object/line that the witness line is attached to is hidden. For example, if the witness line is attached to a reference line. If you hide the reference line then the respective dimension will no longer be shown until the reference line is unhidden.
Tue, Nov 17, 2015 at 3:02:41 PM | Dimension Glitch?
Your problem is probably a process problem.  When you dimension, Revit tells you what you are dimensioning to/from in the lower left corner.  If you have two objects with coincidence lines, you may be picking the wrong object.   If that object is later turned off, moves above the cut plane or hidden, then that portion of the dimension will go away.  You can see if that was the problem by removing your edit and turning on all categories.
Revit 2013 Stair Glitch
Mon, Dec 17, 2012 at 11:16:11 AM
Stair Rail Glitch
Thu, May 7, 2015 at 7:35:59 PM
Activate Dimension
Tue, Dec 13, 2011 at 12:53:44 PM
Revit 2010 Glitch?
Fri, May 8, 2009 at 10:36:47 AM
Dimension strings not adding up to the total length dimension string (2017)
Fri, Mar 23, 2018 at 1:33:58 AM
Page generation time: 7.0924
