14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> reducing file size when importing into VIZ 2006
16 Posts No Rating |
anyone know how to reduce the size of the file when importing revit into viz?
i converted the revit model into DWG and from there imported into viz and the file size is huge.... which hangs computer. i tried to use the file link manager in viz to link the revit file and still the file size is huge.
any suggestions out there?
When Exporting the revit model turn off categories of elements you will not necessarily need that are going to increase the file size... For instance: Furniture, lights etc...
You can also add a scope box only export out the part of your model your interested in by cropping out unwanted info.
HTH.
thanks mr spot again!
reducing file size |
Wed, Oct 11, 2006 at 4:01:48 PM
Reducing File Size |
Thu, Sep 22, 2005 at 6:52:53 PM
Having difficulty reducing file size to less than 400mb! |
Fri, Nov 19, 2010 at 10:12:59 AM
'save as' reduces file size - a good method? |
Tue, Sep 23, 2014 at 7:36:45 AM
Importing or linking 3D CAD file |
Thu, Oct 1, 2009 at 5:04:49 AM
