30 Users Online (28 Members):
Forums >> Revit Building >> Technical Support >> Line weights in detail families
I have several detail items where I want to change the line weight. Usually to heavier. But under the manage / additional settings command it is not an option. Even when I atempt to edit the object style and make the line heavier when I import it in it does not take. Anyone have a fix to this?
Thanks,
AAron
Detail items have their own sub-categories. In object styles or in view-VG, expand that and change the appropriate sub-category.
Ah I did not think of in-view vg. I will take a look at that! Thanks WWhub. It is annoying that I cannot even use the lineweight tool on some of the detail items.
Line weights reverting to standard |
Thu, Jan 6, 2011 at 7:10:38 AM
Detail Lines Follow Model Line Weights Problem |
Fri, Sep 9, 2011 at 9:55:51 AM
Revit Structure Questions Line Weights |
Wed, Jan 16, 2013 at 3:33:32 PM
Revit line weights |
Wed, May 15, 2013 at 10:49:44 AM
Detail Component line weights |
Wed, Jan 7, 2009 at 4:44:09 PM
