Forums >> Revit Systems >> Technical Support >> Orange lines in 3D view on self-made revolved family features
Mon, Nov 16, 2015 at 8:55:03 AM | Orange lines in 3D view on self-made revolved family features
magnuskilea
Hi
I have made several pipe and mechanical equipment using the revolve function. But when I load them into my model an orange line appeares representing the sketch from which I revolved my feature. I have tried turning off virtually every feature in the visibility/graphics panel, but I cannot hide them... Any tips?
Thanks
Mon, Nov 16, 2015 at 9:07:17 AM | Orange lines in 3D view on self-made revolved family features
Did you do any linewortk in the family?  I doubt this is your revolve sketch - instead get rid of your layout lines which must be 3D.
Tue, Nov 17, 2015 at 1:19:31 AM | Orange lines in 3D view on self-made revolved family features
magnuskilea
Thank you for your reply WWHub.
I think I made the shape as a line first, outside the revolve feature. Then I selected the lines to use as a basis when revolving. Im used to this from other CAD software. Do you mean that I should not do this in Revit, and only sketch within the 3D tools (extrude, revolve etc.)?
Thanks again!
Tue, Nov 17, 2015 at 7:13:03 AM | Orange lines in 3D view on self-made revolved family features
Yes, why sketch twice?
Tue, Nov 17, 2015 at 7:20:37 AM | Orange lines in 3D view on self-made revolved family features
magnuskilea
Ok! but I don't sketch twice, I use model lines to sketch the outline. Then I choose the revolve tool, and just pick those lines. Thought it might delete my revolve if I just deleted the lines afterwards, but nothing bad happenedSmile
Tue, Nov 17, 2015 at 8:41:14 AM | Orange lines in 3D view on self-made revolved family features
Picking (pointing) to a line is a sketch ....
A very, very long time ago, we used layout lines to draft almost everything, especially when we inked.  Now it is a complete waste of time - just sketch it once.  With a similar thought - Don't layout walls using lines - use walls! ...while watching your temporary dimensions.
Fri, Nov 20, 2015 at 1:22:27 AM | Orange lines in 3D view on self-made revolved family features
magnuskilea
Ok, now I get it! Thanks for clearing that up, and saving me some time and effort!
Wed, Nov 25, 2015 at 7:56:21 AM | Orange lines in 3D view on self-made revolved family features
Pikachu123
Not to intervein, but on the subject, if you do the same thing with reference lines, and snap your dimensions to then, i found you get hte best results regarding parametric families, and contrainsts. That can be one of the most frustrating things, when you think you done with a family file that has like 10 different types, and 1 of them do not work because "Constraints are not satisfied" ... UGH!, like charlie-brown-and-the-punt-fakout UGH! =)
Lines made with linework tool disappear
Wed, Sep 21, 2011 at 7:46:23 AM
Strange orange lines in linked file
Tue, Sep 9, 2008 at 11:10:01 AM
colored reference lines...or something
Wed, Sep 4, 2013 at 3:42:22 PM
Made a new family but ant rotate it properly
Mon, Jun 13, 2011 at 12:32:45 PM
Void extrusions showing up orange even when rendered
Fri, Mar 8, 2019 at 1:35:44 PM
Page generation time: 1.2713
