10 Users Online (8 Members):
Forums >> General Discussion >> Revit Project Management >> floor plan views
I have a problem that all new levels that I creat are opened as structural plan views and not floor plan view.
for example i added basment level (-3.00) and i get a new plan view under structure.
thanks Hagay.
In the level command active, before you place a level, highlight the plan view type you want on the option bar. Revit will remember your selection next time you place a level.
thanks,
when i check the "make plan view"
all the option i have are structural types
is there a way to add the floor or ceiling type?
Structure does not have RCP's if I remember correctly.
Under the Revit R dropdown/user interface, make sure you have the Architecture tab and tools checked.
thanks,
i found a place to change the value to architecture instead of strctural in the Revit R dropdown via the "option" box
in the general there was a "view option" and it relate to the defualt discipline - it was structural and i changed to Architecture.
so when i create new level it gives me a view with Architecture discipline but it still creat it under the structure plans and not
under the floor plan.... ?
section line continuity between floor plan views |
Thu, Aug 31, 2006 at 4:54:20 PM
Elevation Level Marker Associated To Wrong Floor Plan |
Wed, Feb 25, 2015 at 10:44:23 AM
My Floor Plan Is Not Showing In Some Views |
Sat, Apr 25, 2009 at 1:54:41 PM
Duplicating a floor plan and Creating a new floor plan |
Wed, Feb 3, 2016 at 7:28:16 AM
Ordering renderings and 3D views when on sheets |
Fri, Jun 30, 2006 at 12:06:04 AM
