Forums >> General Discussion >> Revit Project Management >> How to make sheet parameters RELATED
Tue, Nov 10, 2015 at 11:42:19 AM | How to make sheet parameters RELATED
uros19
Hello all,
Here's the issue. I am working on 6 townhouses. I orginized the project beautifully and went around a lot of stuff, but still have few little things. Each house is filed separately, so each house has it's own adress. i orginized sheets in different filing sets for each adress. So I would like to have the possibility, when I assign a filing set to the sheet, to have automaticly the right Adress showing on the sheet. I created different parameters for each adress, and the only way I found was to select by yes/no on the sheet which adress I want to show and which not, but having 60-70 sheets per filing set it would be great if Revit could do that for me. Any ideas???
Thanks
Wed, Nov 11, 2015 at 7:17:41 AM | How to make sheet parameters RELATED
Why not just create different sheet types with the address in the sheet family.
Thu, Nov 12, 2015 at 4:47:23 AM | How to make sheet parameters RELATED
uros19
Well, I can just make the adress parameter Sheet related and put it manually on each sheet, instead of having 6 familes. The fact is that ion this way there is space for error, considering the number of sheets. That's why I'm searching a way to make it automatic, when the sheet is in the filing set 1, the adress is 1, in the filing set 2, the adress is 2. etc....
Wed, Nov 25, 2015 at 8:37:49 AM | How to make sheet parameters RELATED
Pikachu123
I use this method with key plans for mutliple areas. You could create a shared paramter and put it into your title block as a label, then intreoduce teh shared parameter to your project, so once you type in a value once for a sheet, it will become a drop down for future filling out.
OR
you can go into your title block ,and just stack the different addresses on top of each other, and make them visisble or not visisble with a instance parameter. This way you can select multiple in your project browser and fill them all out at once.
I know it's not instantanious, but the only way i think you can accomplish what your asking for is to have them be separatoe projects, and go to the Manage Tab > Project Information > Fill out the Project NAme & Project Address > then go intot your title block, and put those lables in the orientation you want. You can only have 1 value per project file though.
Thu, Nov 26, 2015 at 5:48:30 AM | How to make sheet parameters RELATED
uros19
Well, your second suggestion is what I used @ the end... But still leaves space to error with so much sheets, I want something automated,: IF THE SHEET IS UNDER FILING SET "HOUSE 1" PUT ADRESS "ADDRESS 1"... I can't have different projects because I have to be able to make changes in 1 file, would be impossible to have 6 different files and make changes to all....
Shared Parameters for Browser Organization
Fri, Nov 9, 2012 at 11:39:27 AM
Sheet Parameters
Mon, Apr 26, 2010 at 2:13:42 PM
Sheet Sub-Categories...
Wed, Nov 7, 2007 at 7:29:16 AM
Delete "stock" Project Info. & Drawing Sheet Parameters?
Mon, Nov 23, 2009 at 4:05:40 PM
sheet index (list) not organizing properly
Thu, Sep 15, 2016 at 4:13:55 PM
Page generation time: 0.6511
