Forums >> Revit Building >> Technical Support >> Changing Stair Material
Tue, Nov 10, 2015 at 9:45:33 AM | Changing Stair Material
Jacob5089
Hi,
I'm working on a house for a project and I have a staircase in the home I am designing. When I do my renderings, the staircase stands out against the rest of the area because it has a default gray texture. I am wondering if there is a way to edit the texture of the staircase to something of my own choosing.
Tue, Nov 10, 2015 at 9:46:25 AM | Changing Stair Material
Jacob5089
My apologies forgot to mention this, using Autodesk Revit 2015 Educational Version
Tue, Nov 10, 2015 at 10:38:51 AM | Changing Stair Material
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Stair by component: Select stair -> edit type -> run type -> materials and finishes
Stair by sketch: Select stair -> edit type -> materials and finishes
Tue, Nov 10, 2015 at 10:43:25 AM | Changing Stair Material
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Edit the stair, under Supports>Right Support Type click the ... to open the Stringer Type properties and you can change the material there, do the same for the left support.  For the risers and treads its under the Contruction>Run Type then click the ...
Thu, Nov 12, 2015 at 8:43:37 AM | Changing Stair Material
Jacob5089
Thank you guys for your help. I can't seem to find an option to change the texture of the railing and the stringer. Any ideas on how I could do that?
Thu, Nov 12, 2015 at 9:17:36 AM | Changing Stair Material
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Railing: dbl click on the railing family name in your project browser (under Families). Type properties window will pop up.
Stringer: hover over a stringer and tab until it’s selectable. Select -> Edit Type -> Material
Sat, Jan 21, 2017 at 4:11:52 AM | Changing Stair Material
JoeAdams
1 Stars: 1 Votes
Which material have you used? We are planning to remodel our home and are wondering about the same i.e. stair material. On someones recommendation, we hired a home renovation contractor and they suggested we Peel & Stick Nonskid Bullnose Carpet Stair Treads, Cobbler Brown, Set, Nylon like materials on our interior theme. Hiring a general contractor NJ who will create beautiful custom designs is always satisfying.
monolith stair extra structure material
Wed, Nov 11, 2009 at 1:29:56 PM
stair material takeoff list
Thu, Jun 15, 2017 at 11:28:46 AM
Stair Material Takeoffs - Volume Calculation Error when Painting
Tue, Dec 10, 2013 at 7:45:46 AM
Phasing and changing material finishes
Wed, Apr 30, 2008 at 11:03:55 AM
Revit Monolithic Stair with Material Finishes
Tue, Apr 14, 2015 at 6:00:26 AM
Page generation time: 1.3613
