Forums >> Revit Building >> Technical Support >> window flip issues
Fri, Mar 31, 2006 at 9:19:59 PM | window flip issues
mvoigt
i have a window family i downloded from here. single_hung-2_1417. the windows are nice however i am having trouble with th flip. I click the flip arrow and the window stays on the inside rather than the pane on the outside of the wall. What is the problem? I am fairly new to revit.
Mon, Apr 3, 2006 at 2:21:09 AM | RE: window flip issues
fazerneil
4 Stars: 5 Votes
Have not tested the files, but sounds like a constraint has not been correctly set up. Try a different window type and see if that works, if it does then it is the original family at fault
FLIP INSTANCE FACING OF BEAM
Fri, Aug 5, 2011 at 10:29:26 AM
Adding a Flip Control
Mon, Dec 5, 2011 at 5:12:51 AM
Window Issues
Sat, Jun 13, 2009 at 10:10:56 AM
Flip Controls in Nested Families
Wed, Jan 16, 2008 at 1:47:48 PM
Flip Control
Thu, Aug 11, 2005 at 7:11:42 PM
Page generation time: 6.2559
