Forums >> Revit Building >> Technical Support >> Elevation won't show in preview and can't be printed out
Mon, Nov 9, 2015 at 9:45:52 AM | Elevation won't show in preview and can't be printed out
rabbitcookies
I have an exterior elevation view on a sheet which can't be shown correctly in preview, also can't be printed. It seems like the elevation is on a def. layer or something which can't be printed. I attached a screen shot for your reference. My other elevation views are fine on the sheet.
Thank you,
Mon, Nov 9, 2015 at 10:18:05 AM | Elevation won't show in preview and can't be printed out
Wht was that image supposed to show us?
Many things don't show up in preview but that typically is never a problem.
Do any of your other views have sketched boundaries that may overlap this view?
Put the view on a new sheet and tell us what happens.
Mon, Nov 9, 2015 at 10:30:51 AM | Elevation won't show in preview and can't be printed out
rabbitcookies
Yes, I tried to place this view on another new sheet and the problem is the same. The elevation view looks fine on the sheet, but just can't be printed. When I tried to print either the sheet or the view itself, nothing showed up except dimensions, tag, grids & levels.
Edited on: Mon, Nov 9, 2015 at 10:31:51 AM
Fri, Nov 20, 2015 at 10:58:59 AM | Elevation won't show in preview and can't be printed out
Username01
I had the same issue happen on a sheet that I was trying to print. I was able to solve the problem by adjusting the crop region boundary control points.
Wall won't show in North elevation
Thu, Oct 9, 2014 at 12:21:15 PM
Structural beam won't show in elevation
Fri, Aug 12, 2005 at 5:22:08 PM
Detail Levels
Thu, Sep 22, 2005 at 1:09:37 PM
walls won't join
Fri, Oct 31, 2008 at 2:31:33 PM
elevation arrowhead don't show up at print
Tue, Nov 14, 2006 at 1:26:57 PM
Page generation time: 1.2791
