Forums >> Revit Systems >> Technical Support >> Offsetting the ends of a blend with a paramter
Sun, Nov 8, 2015 at 11:27:16 PM | Offsetting the ends of a blend with a paramter
Cousins
Hi All,
As the title suggests I am trying to work out how to offset the ends of a blend from thier center points via a parameter that can be changed at will.
Does anyone have any tips on where to start?
Regards,
Mon, Nov 9, 2015 at 6:28:43 AM | Offsetting the ends of a blend with a paramter
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Put blend profiles on the opposite sides of the ref. line. Create a parameter to control the length of the ref. line. Make sure the profiles are on the ref line’s end planes.
Mon, Nov 9, 2015 at 10:18:18 PM | pijpiwo
Cousins
Quoting pijpiwo from 2015-11-09 06:28:43
That changes the lenght of the blend, but what if I want to offset the two ends on a different axis?
Regards,
Mon, Nov 9, 2015 at 11:57:19 PM | Offsetting the ends of a blend with a paramter
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Sorry, misunderstood your question. Create swept blend with straight path then. Insert profiles (do not sketch) and the offset parameters are already done for you.
Wed, Nov 11, 2015 at 8:58:43 PM | Offsetting the ends of a blend with a paramter
Cousins
Was not sure how to get a swept blend to work as I have never used it before.
I managed to achieve my offset paramater by overlaying 2 reference planes and adding a paramater to control the them, then attacheding the center of one end of my blend to them.
This seems to work fine.
column height paramter
Wed, Sep 26, 2007 at 9:11:53 AM
Create form tool for components other than mass - Revit Architecture 2012
Mon, Oct 20, 2014 at 4:15:58 PM
wall solid blend
Tue, Aug 18, 2009 at 3:56:25 PM
Void Blend not showing correct cut
Tue, May 5, 2009 at 11:21:00 PM
Massing Blend
Tue, Mar 20, 2007 at 11:58:48 AM
Page generation time: 1.0278
