Forums >> Revit Building >> Technical Support >> wall no being cut in plan
Fri, Nov 6, 2015 at 3:24:59 PM | wall no being cut in plan
Warchitect
4 Stars: 5 Votes
See the picture. Revit 2015
There is an instance opening in the concrete wall. so as to place a curtain wall fills that space (as a store front thingy). the cut plane, in plan cuts, it all but only shows the glass, not the mullions, and also doesnt show the instance opening cutting the wall. you can see on the 3d that everything is basically OK. the cut plane in plan is behaving weird. ive got the cut plane set at about 3 feet above the floor...
any suggestions?
Edit: got it. cut planes are weird...the glazing and concrete are not intersecting, but was being shown that way. I dont know how it got fixed itself...
Edited on: Fri, Nov 6, 2015 at 3:30:37 PM
I can't see wall with section lines eventhough cut plan passes through the wall!
Mon, Sep 15, 2014 at 9:42:29 PM
Wall sections cut from elevation... now not seen on plan
Fri, Mar 9, 2012 at 11:05:12 AM
Cut Pattern in Plan vs Section
Tue, Aug 25, 2009 at 8:47:59 AM
Plan view not showing cut wall
Tue, Sep 22, 2015 at 8:08:14 AM
Wall Cut Pattern Plan View vs. Section
Fri, Jan 6, 2012 at 11:19:21 AM
Page generation time: 2.2237
