16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> No Equal Toggle for Arc Dimensions?!
Is this true?! Hopefully I'm just dealing with a corrupt element, but please tell me you can do equal dimension for an arc dimension string.
I don’t think so. What exactly are you trying to do? A picture would help to better understand your problem.
Have you tried a radial array?
It was for a curtain wall. It seems like this can only be managed in the curtain wall type for spacing of grids. A-nnoying, but workable. Seems like an oversight not to include this functionality. I'm sure there's a "good" reason though. Thanks.
It works for grids.
EDIT: Never mind, you asked for arc dims.
Edited on: Fri, Nov 6, 2015 at 2:05:55 PM
That's a good point though. Thanks for your reply!
EQUAL CONSTRAINT DIMENSION |
Mon, Jan 10, 2005 at 1:06:29 PM
Aligned dimensions for centering curtain wall door |
Fri, Dec 23, 2011 at 6:26:40 AM
EQ Display in dimensions Revit 2009 |
Tue, Mar 23, 2010 at 3:28:36 PM
Centering Elements WITHOUT using the "Equal" dimension |
Mon, Nov 24, 2008 at 2:38:42 PM
Divide arc by length |
Fri, Sep 7, 2007 at 6:17:46 PM
