Forums >> Revit Building >> Technical Support >> Ceilings not appearing
Wed, Nov 4, 2015 at 3:36:55 PM | Ceilings not appearing
kstar
I am using Revit Architecture 2015, Student Version.
My project is setup as follows:
Level 1: Where all floors, furniture, etc. are located.
Level 2: Some walls that start on Level 1 go up to Level 2
Level 3: Some walls that start on Level 1 go up to Level 2.  I also have some clerestory windows that were created using a curtain wall that goes from Level 2 to Level 3.
My ceilings are visible in 3d, but I cannot see any ceilings in any of my ceiling plans.
Visibility settings are correct.  I thought the problem were the View Range settings but the only items I can adjust are Primary Range: Top and View Depth Level.  Both are set to Unlimited and still no change.
Any thoughts?
Wed, Nov 4, 2015 at 3:59:19 PM | Ceilings not appearing
Because you are a beginner, we need to ask some questions.
Do you know what a Reflected Ceiling Plan is and how it is done in Revit.   It is not just another floor plan.   Read your HELP on RCP if you don't understand.
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-D14C26D1-0BE6-41E4-A4CC-870459A0819B
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-58711292-AB78-4C8F-BAA1-0855DDB518BF
In order for a ceiling to show, it has to be in view, the category has to be on in VG and the ceiling can't be hidden by something else - like the next floor.
Wed, Nov 4, 2015 at 4:10:39 PM | Ceilings not appearing
kstar
Thank you for your response.
I have used the RCP before but maybe am not remembering it well!
- Yes, VG settings show ceilings as "On."
- I don't have any floors except on Level 1.  Levels 2 and 3 are only there for my clerestory windows so there shouldn't be a floor covering the ceiling.
- I can see and select the ceilings when I am in the Floor Plans for Levels 2 and 3.
- I look at the drawing in 3D the ceilings appear exactly where they should be with no obstructions.
What I actually want to do is a lighting plan that I can generate from the RCP.  I can use the Level 2 Floor Plan as work around for my class project , but I assume I should be using the RCP for this?
Wed, Nov 4, 2015 at 4:42:03 PM | Ceilings not appearing
DON'T USE A FLOOR PLAN!  That's what a RCP is for.  A RCP is looking down in plans but with a reflection of what is above.  Only what is above the cut plane will show 'reflected'.
You write: "... I can see and select the ceilings when I am in the Floor Plans for Levels 2 and 3....."   You should not be able to see a ceiling for a level in a floor plan because it would be above your cut plane.
Wed, Nov 4, 2015 at 4:48:40 PM | Ceilings not appearing
kstar
Sorry the system reposted my last response by accident.  The cut plane must be my issue.  I will look for directions on fixing this.  Thank you!
Complex ceilings
Thu, Oct 8, 2015 at 1:02:54 PM
Vector Printing - Ceilings Disappear
Wed, May 28, 2014 at 9:12:41 AM
Sloped Ceilings
Thu, Jan 23, 2014 at 4:54:40 PM
14
objects from 2nd level appearing in 3rd level why?
Mon, May 20, 2013 at 4:35:41 PM
Model In Place Ceilings Not Scheduling??
Wed, Jan 15, 2014 at 10:55:35 AM
Page generation time: 2.8099
