Forums >> Revit Systems >> Technical Support >> Rendering was working and then it lost all the material settings.
Mon, Nov 2, 2015 at 11:22:01 PM | Rendering was working and then it lost all the material settings.
BrianEmerich
I was in a fairly new project and had added materials to walls, floors and doors. I did a few practice renderings as work progressed. Then I tried to render again and it came up without any of the materials. The materials are still attached but the renderings come out similar to standard model without materials attached. I also notice the default 3D was not showing all the elements either. Roofs did not show. I deleted the 3D view and called for a new one and it came back but still no materials. I opened a new file and pasted some of the elements in and they rendered again properly. Then it stopped working in the new file as well. I have shared the parameters in another file which seems to be working normally.
Mon, Nov 9, 2015 at 4:59:21 PM | Rendering was working and then it lost all the material settings.
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Any other computers you can test the file on ?
Material Editor Lost/Rendering Broken
Tue, Oct 27, 2015 at 1:18:16 PM
Having trouble creating a material in Revit 2009
Tue, Feb 24, 2009 at 9:41:25 AM
lights not working in 3D or rendering
Thu, Jul 11, 2013 at 10:56:36 AM
lost accurender material file
Sun, Aug 31, 2008 at 12:11:56 AM
Rendering Tab
Tue, Sep 9, 2008 at 3:05:16 PM
Page generation time: 3.7001
