22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Door Jambs
1 Posts No Rating |
How do I get the door jambs to show in plan view? In my CBS construction plans I must dimension to the edge of the block, not to the edge of the door or the centerline of the door. Do I have to create this as a separate type of door?
You need to create new door families with an actual frame drawn as you want it to appear.
10 Posts No Rating |
yea the best is to create special families w/ reference plans where you want the dimension.
or take the doors u already have - increase the detailing level of your plan - and use "tab" to change the line cathed in Dimension command.
thanks
wall layer not wrapping for door family with jambs |
Tue, Sep 1, 2015 at 10:34:33 AM
door with jambs and adj swing |
Thu, Feb 12, 2009 at 8:46:01 AM
Doors, Door jambs, and placement in walls |
Fri, Feb 22, 2013 at 9:30:07 AM
Door Frames |
Fri, May 16, 2008 at 8:46:11 AM
Radius window jambs |
Fri, Jul 6, 2007 at 8:55:13 PM
