Forums >> Community >> Newbies >> I'm new to this....HELP! Why are all my designs white when I open them?
Tue, Oct 27, 2015 at 5:06:22 AM | I'm new to this....HELP! Why are all my designs white when I open them?
3mma
Hey guys.  I'm semi-new here, and I have a question.  Whenever I try to download carpets or rugs (and it might be with other objects, haven't tried it yet), the images always come up white.  No design, no nothing.  Just the basic outline in black.  I'm using Revit 2015.  What is this and how can I fix it?  Thanks!
~Emma
Tue, Oct 27, 2015 at 5:54:14 AM | I'm new to this....HELP! Why are all my designs white when I open them?
Shatner86
Shatner86 Avatar
5 Stars: 2 Votes
hi Emma,
I have a feeling you just need to change your Visual Style from Hidden to Realistic. I have uploaded two pictures below to show you where you can change visual style.
Hope this helps.
Kind Regards,
Shatner86
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein
Tue, Oct 27, 2015 at 7:20:42 PM | I'm new to this....HELP! Why are all my designs white when I open them?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
hotkeys for cycling through visual styles:
HL = hidden line = black and white
WF = Wireframe = black lines and transparent
SD = Shaded with edges = colors
RY = Raytrace = newer feature, weird pseudo-rendering
?? - Consistent colors - same as SD but doesn't shade differently at angles
?? - Realistic - uses rendering materials but no light calculations
Hit the cube at the bottom of any view window to see more options.
Thu, Oct 29, 2015 at 5:01:10 AM | Shatner86
3mma
Quoting Shatner86 from 2015-10-27 05:54:14
hi Emma,
Hope this helps.
Kind Regards,
Shatner86
Thanks for the help, but it's still not working.  I set it to realistic, and it looks like the file attached.  Any other ideas?
Thu, Oct 29, 2015 at 5:15:58 AM | I'm new to this....HELP! Why are all my designs white when I open them?
Thread Post Kudo! #5
Shatner86
Shatner86 Avatar
5 Stars: 2 Votes
Hi Emma,
Could you attach the family?
I'm assuming when you ahd the drawing in Hidden Line that is when you had the "the images always come up white.  No design, no nothing.  Just the basic outline in black. " or did switching between the views not help?
Re-reading your post, when you "images" do you mean materials / pictures on the item?
If so, maybe this link would be of help?
https://forums.autodesk.com/t5/revit-architecture/insert-image-to-revit-family-and-save-as-family/td-p/4434307
Kind Regards,
Shatner86
-Albert Einstein
Mon, Dec 7, 2015 at 5:15:31 AM | I'm new to this....HELP! Why are all my designs white when I open them?
3mma
@Shatner86:Thanks so much!  I checked out the website, and that was what I was looking for.
Can't open REVIT
Thu, Sep 30, 2010 at 12:48:39 PM
Converting things to white
Thu, Dec 5, 2019 at 9:47:09 AM
frosted glass
Tue, Jul 10, 2007 at 10:47:10 AM
Can't open a Revit file. Never saw this error message before!
Thu, Aug 7, 2008 at 4:57:55 PM
White walls are dark grey when rendered?
Wed, Aug 10, 2005 at 10:57:54 PM
Page generation time: 0.4467
