26 Users Online (24 Members):
Forums >> Community >> The Studio >> HELP With Bump Maps!!!!!!!!!!!
Can we use our own bump maps in Revit 8.0 or only the three that is shows
39 Posts No Rating |
dont hold me to this but i think you can use your own.
----------------------------------- vampyre
I want to suck your blood. :z
3 Posts No Rating |
I'm using 2008 but it should be the same...If you add a map in the map section above the procedural bump each map you add allows you to edit the bump on it or how much of that maps colour becomes recognisable as a texture. If you just want a bump section its best to use a greyscale image of varying shades determining different heights.. you should be able to figure out the heiht by eye... put colour to 0 and just use the greyscale to bump... then add another map for colour and texture...thats the way I do it.... you can get really clean results this way...
bump maps in new materials |
Wed, Dec 14, 2005 at 5:43:26 PM
Help Changing Accurender bump map texture colour |
Tue, Oct 19, 2004 at 6:29:51 PM
Custom Material |
Mon, Jun 29, 2009 at 9:04:49 AM
Material maps |
Tue, Oct 12, 2004 at 7:01:05 PM
Maps and Render Times |
Mon, Feb 8, 2010 at 3:54:44 PM
