9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> How do you rotate surface pattern on stair treads and landings?
well, if your surface pattern is a model hatch instead of a drafting hatch, you can select a line of the hatch (may requiring hitting tab a few times) and then rotate or align your selected line with some model feature, like a tread nosing.
This is also going to rotate any render material associated with the hatch, FYI.
Edited on: Fri, Oct 23, 2015 at 2:04:25 PM
That is exactly my problem. It is a model pattern, hit tab, was able to pick the line, but it can not rotate or move.
Unable to rotate/align surface pattern on stairs |
Thu, Aug 28, 2014 at 7:29:20 AM
Stairs - steel & precast conc treads |
Mon, Dec 20, 2004 at 12:46:06 AM
Stair Surface Pattern Not Displaying |
Wed, Sep 8, 2010 at 10:05:09 AM
Rotate surface pattern on a model-in-place blend |
Fri, Mar 30, 2012 at 3:47:08 PM
Surface pattern problem |
Tue, May 18, 2010 at 9:15:56 AM
