Forums >> Community >> Newbies >> Curtain wall not cutting through moulding
Wed, Oct 21, 2015 at 7:17:37 PM | Curtain wall not cutting through moulding
lavendert8
I am working on a renovation project where we are adding a curtain wall that cuts into the existing moulding at the top of the wall. However, when I place the curtain wall the moulding is not cutting out where the new curtain wall is. I created this wall myself with a sweep within the wall type.
Is there any way to get the moulding to cut out where the new wall is. Please see attached.
Thu, Oct 22, 2015 at 7:30:08 AM | Curtain wall not cutting through moulding
I am always surprised at users that post images without pointing out the problem.   I can see the CW but I don't have a clue as to where this 'moulding' is.
Should the moulding be copletely cut or only partially?  Communication is what this is all about.
Thu, Oct 22, 2015 at 11:49:27 AM | Curtain wall not cutting through moulding
lavendert8
My apologies. Where the red line is is where it cuts into the moulding and the purple is where the moulding is. I hope this clears things up.
Thu, Oct 22, 2015 at 1:32:39 PM | Curtain wall not cutting through moulding
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Can you attach a section through that area for us?
Thu, Oct 22, 2015 at 2:23:27 PM | Curtain wall not cutting through moulding
I kind of thought it may be what you point out but that is definitely NOT a moulding!  I've never seen a moulding larger than 8-10".
As it is now, your sweep will only cut all or nothing but to cut, the intersection has to be more than half way.
Edit your wall definition - the sweeps and set it to be cutable.
Thu, Oct 22, 2015 at 2:53:44 PM | Curtain wall not cutting through moulding
lavendert8
Making the sweep cuttable worked. Thank you.
Adding quarter round moulding to existing base board moulding
Tue, Nov 20, 2007 at 8:43:48 PM
Cutting a complex Curtain Wall Panel
Thu, Apr 17, 2014 at 9:44:49 AM
Crown Moulding Return
Thu, Aug 22, 2013 at 2:52:28 PM
baseboard moulding
Fri, Jan 27, 2017 at 10:40:33 AM
wall wrapping at curtain wall "inserts"
Tue, May 20, 2008 at 6:29:51 AM
Page generation time: 1.8027
