Forums >> Revit Building >> Technical Support >> Dimension Crop Box
Wed, Oct 21, 2015 at 1:36:02 PM | Dimension Crop Box
lpluger21
I have my floor plans on my sheet but my property lines exceed the width of my sheet so you do not see the full extent of the property, which is fine. I have to be able to dimension from my property line to my setback line and have it display on my sheet. When the crop is activated it makes the dimesnion completely disappear. is there anyway to override this and make the dimension partially show on the floor plan?
Wed, Oct 21, 2015 at 2:00:24 PM | Dimension Crop Box
Use the view break on the view crop to break the view into two parts and to keep your property line and thus your dimension.
Read this help:
Edited on: Wed, Oct 21, 2015 at 2:02:54 PM
Wed, Oct 21, 2015 at 2:20:44 PM | Dimension Crop Box
lpluger21
Would you happen to have another suggestion. If I do it that way the second part of the drawing will be off the page, and when I go to print it throws my drawing off center.
Wed, Oct 21, 2015 at 3:17:11 PM | Dimension Crop Box
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Grab these blue arrows and pull the parts closer together
Wed, Oct 21, 2015 at 3:17:51 PM | Dimension Crop Box
Read the HELP please!  You can adjust the break point and move the split windows together so that both ends of your property are close enough together to fit on your sheet.
Annotation lines outside the crop region
Thu, Jun 16, 2016 at 8:55:13 AM
Crop Region out in space
Fri, Sep 18, 2009 at 1:47:39 PM
Crop box
Mon, Jan 23, 2006 at 9:09:24 AM
Backwards Crop Box on Interior Elevation
Mon, Sep 24, 2012 at 2:02:32 PM
dimension text un-movable when crop regions applied to a wall section?
Wed, Feb 14, 2007 at 8:40:59 AM
Page generation time: 1.5251
