Forums >> Revit Building >> Technical Support >> Views on sheets cropping eachother
Wed, Oct 21, 2015 at 1:17:36 PM | Views on sheets cropping eachother
larmstrong
Has anyone ever encountered this issue? I have views on a sheet cropping out information from eachother. The polygon crop tool was used, the annotative crop is not in the way, and it's not the viewport because that doesn't line up with where the other drawing is being cut. I checked for a plan region that may be interferring and that came up negative as well. Any help would be greatly appreciated. I feel like there would be no point to the polygon crop if this weren't fixable, so there must be some solution that I'm missing.
Wed, Oct 21, 2015 at 1:19:04 PM | Views on sheets cropping eachother
larmstrong
Revit version is 2015 just FYI
Wed, Oct 21, 2015 at 1:21:12 PM | Views on sheets cropping eachother
You need to understand that the sketched crop simply adds a masking region.  That is what is hiding the other view.   Views on sheets did have a placement order for what's on top.  You might play with the order you place the views on the sheet.
Thu, Oct 22, 2015 at 10:54:20 AM | Views on sheets cropping eachother
echo66
Wot he said. Remove the views from the sheet & begin again, changing the order of views placed on the sheet. Had to do this a lot.
Fri, Oct 23, 2015 at 9:27:51 AM | Views on sheets cropping eachother
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
We have had issues using the sketched crop region in general. Causes crashing and can create MASSIVE PDF files that will bring things to a hault. It's not the  answer you want but we had askedeveryone to NOT use the sketched crop region. Not sure if that has improved since 2014.
CROPPING VIEWS ON SHEETS??
Thu, May 18, 2006 at 2:35:14 PM
cropping viewport on sheet is cropping my floor plan!
Tue, May 22, 2007 at 3:51:12 PM
Printing Issues - unnecessary cropping and text shifting
Thu, Oct 16, 2008 at 8:35:47 AM
cropping region acting weird
Wed, Jul 16, 2008 at 3:15:20 PM
Sheets and Views
Wed, Mar 17, 2021 at 3:23:24 PM
Page generation time: 0.2392
