Forums >> Revit Building >> Technical Support >> Mullion
Fri, Oct 16, 2015 at 2:37:56 PM | Mullion
gettingthere
hI
is there any way to add a mullion or a transom to a window family without going through the complexities of making a new window from scratch ?
Fri, Oct 16, 2015 at 8:45:45 PM | Mullion
CDWdavid
5 Stars: 5 Votes
You can use extrusion or sweep to add mullions into existing window families.
Sat, Oct 17, 2015 at 1:35:28 AM | Mullion
gettingthere
Could you expand a little on the process please ! i am still relatively new and finding it hard to amend the window family ?
Thanks in anticipation
Sat, Oct 17, 2015 at 9:53:54 PM | Mullion
CDWdavid
5 Stars: 5 Votes
Open a window family, save to a different name.
Click "Create", the Extrusion and Sweep panel will be shown.
Open the Family Guide, and follow the directions.
You can use Extrusion or Sweep for mullions, use Sweep for stops, and use Extrusion for glazing; also you can learn how to play with materials through this exercise.
To make families is the most important step to learn Revit.
A non-parametric family should be easy.
Good luck!
mullion ang transom not fitting well [ 1 2 ]
Wed, Oct 9, 2013 at 11:42:10 PM
23
Curtain Mullion eats into vert mullion
Thu, Jan 22, 2015 at 4:49:08 PM
mullion join at angled mullion 2017
Sat, Oct 21, 2017 at 11:53:54 AM
parametric mullion
Thu, Feb 26, 2009 at 11:57:56 AM
Mullion Profile
Tue, May 16, 2006 at 10:37:15 AM
Page generation time: 0.4971
