Forums >> Revit Building >> Technical Support >> Changed the project base point coordinates and lost my level lines!
Fri, Oct 16, 2015 at 5:41:02 AM | Changed the project base point coordinates and lost my level lines!
MrPotatoHead
Hi guys,
As the subject states, I had created a model early on without any survey information on. I recently recieved said information and changed the project base point to locate a corner of my building to the correct easting and northing point. However, after doing this I came to realise the levels that were previously shown on my elevation views have all disappeared.
I have done some online searching and I've tried creating a scope box then apply a new elevation along with the "select all instances" option to the scope box, but this was to no avail. My guess is that my model was sent so far off its original location after putting in the new project base coordinates so my scope box just cant extend out enough to cover the elevations?
I'm sure I could have prevented this from happening in the first place but I really just need a solution to this. Any help on this matter is greatly appreciated!
Thanks
Fri, Oct 16, 2015 at 6:44:16 AM | Changed the project base point coordinates and lost my level lines!
Uncrop your elevation and do a zoom E.
Fri, Oct 16, 2015 at 6:56:16 AM | Changed the project base point coordinates and lost my level lines!
MrPotatoHead
It worked. Helpful as always WWHub, Thanks!
Project Base Point
Thu, Jul 2, 2009 at 6:24:59 AM
Survey Point and UTM coordinates
Mon, Jun 20, 2016 at 3:50:02 PM
Shared Coordinates Published Incorrectly
Mon, Jan 11, 2016 at 6:44:07 PM
specify coordinates at a point
Tue, Oct 4, 2005 at 12:56:17 AM
Level that reads both Project Base Point and Project Survey Point
Tue, Jun 9, 2015 at 9:39:37 AM
Page generation time: 0.9468
