5 Users Online (3 Members):
Forums >> Revit Building >> Technical Support >> Massing problem
I am trying to model a mass family with a certain set of parameters . Initially starting with only ref planes and points i would later go on to model the forms . But i am stuck at the ref planes and points level itself .
In the attached file the geometry has 4 ref planes in triangular form . Point D is hosted on line . The requirement is that the angle at D should remain 90 deg . And i should be able to adjust length AB and AD so that points A, C and D adjust according to the constraint .
Now i have been able to constrain angle at D to 90 deg . And set length AB as a parameter which flexes properly .
But length AD is not flexing when set as parameter. It flexes otherwise . But not when as a parameter . ( see images )
Massing |
Mon, Jun 22, 2009 at 9:18:46 AM
Revit 9.1 massing not printing correctly |
Thu, Oct 4, 2007 at 11:12:47 AM
why my massing can't not be a solid? |
Fri, Feb 11, 2011 at 8:26:42 PM
Massing printing problems |
Tue, Feb 9, 2010 at 8:11:10 AM
curve sloped massing wall problem (plz HELP!!!) |
Wed, May 9, 2007 at 5:15:43 AM
