Forums >> Revit Building >> Technical Support >> Render goes ok but when i change angle - the render is black
Sun, Oct 11, 2015 at 5:57:23 AM | Render goes ok but when i change angle - the render is black
danezeq
Render goes ok but when i change angle -  the render is black. why is that happen?
Here it is:
https://www.youtube.com/watch?v=3KktVWTlGk4
Thu, Oct 15, 2015 at 7:40:39 AM | Render goes ok but when i change angle - the render is black
KimTaurus
KimTaurus Avatar
5 Stars: 3 Votes
When you rotate the view, you change the position of the camera.
In the general 3D view, in Project Browser > Right-Click on the 3d camera view > Show Camera. This shows the camera and the view lines in the 3D model.
When rotating the view it is possible the camera is situated inside a geometry or below the toposurface. you don't always see the in the actual camera view.
Mon, Oct 19, 2015 at 5:35:08 PM | Render goes ok but when i change angle - the render is black
danezeq
But it's happening of regular 3d view- i'm not talking about camera (perspective) view!
Tue, Oct 20, 2015 at 1:12:58 AM | Render goes ok but when i change angle - the render is black
KimTaurus
KimTaurus Avatar
5 Stars: 3 Votes
Add a sectionbox to the view and cut away everything but the building. This way you can make sure nothing is blocking the camera (3D view is also a type of camera).
Tue, Oct 20, 2015 at 4:38:11 AM | Render goes ok but when i change angle - the render is black
danezeq
thank you i'll try this.
image when "render in cloud" black
Tue, Jan 14, 2014 at 8:51:32 AM
I"M HAVING DIFFICULTY CHANGING THE RENDER COLOUR OF MY BALUSTER/STAIRCASE
Wed, Jan 19, 2011 at 4:52:18 PM
14
Baluster's are rendering black??
Tue, Feb 23, 2010 at 9:08:22 AM
Material's render a different color
Thu, Oct 20, 2011 at 8:08:58 PM
Render Appearance Library - Reloading
Wed, Mar 18, 2009 at 1:04:31 PM
Page generation time: 0.4821
