Forums >> Revit Building >> Technical Support >> "Tunnel" from AutoCAD file
Fri, Oct 9, 2015 at 11:26:56 AM | "Tunnel" from AutoCAD file
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I was asked to take the attached autocad file and create what is essentially a sweep to form a type of "tunnel".  There are a TON of points that come in from the AutoCAD file, anyone know if an easy way to turn these lines into into a solid shape?
Fri, Oct 9, 2015 at 11:53:00 AM | "Tunnel" from AutoCAD file
I think you limit that to a cross section and simplify it.  If you rotate the back view somewhat, you have a fairly simple form wit sloping sides, rounded corners and a flat top and pottom.  Four lines and 4 curves.
Fri, Oct 9, 2015 at 2:00:24 PM | "Tunnel" from AutoCAD file
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
So you're saying to re-draw the lines as basiaclly a box with rounded corners?
How to construct a freestanding tunnel?
Thu, Nov 24, 2011 at 3:02:46 AM
Linked AutoCAD file printing grey
Mon, Jul 26, 2010 at 10:07:25 PM
Opening 2008 file in 2009 causes "Unrecoverable error" crash
Tue, Jul 28, 2009 at 1:36:33 AM
File is "past it's end"
Wed, Dec 19, 2007 at 9:35:12 AM
"File not saved"
Mon, Nov 26, 2007 at 5:41:46 PM
Page generation time: 1.6577
