Forums >> Revit Building >> Technical Support >> Using 2d group for Wall section, section details called out from wall section?
Fri, Oct 9, 2015 at 9:16:30 AM | Using 2d group for Wall section, section details called out from wall section?
rabbitcookies
I use Revit 2014 Architectural. Just want to know how you guys deal with wall sections & section details called from the wall sections.
When I cut a wall section from the Revit model, I draw 2d items over model walls, windows & ets. and I group the items because it's easier to control. If I made any callouts from the wall section, I paste the group "align in current view" in the callout views.  By doing that, if I change the anything in the 2d group, both wall section & section detail (the callout) will be updated at the same time.
It works fine except I have concerns if the groups makes the model size bigger. Also, different scales of the wall section & section detail cause some lines show fine in the bigger scale (ex. 3"=1'-0"), but congest in the small scale (ex. 1/2" = 1'-0")
Fri, Oct 9, 2015 at 9:55:38 AM | Using 2d group for Wall section, section details called out from wall section?
My process is in this post.  I really try to use as little 2D work as I can.
As far as the grouping goes, groups do not necessarily make your model larger.  However, you should never be grouping elements that are only used once.
Fri, Oct 9, 2015 at 10:50:56 AM | Using 2d group for Wall section, section details called out from wall section?
rabbitcookies
Yeah, thanks WWWHub. I try to minimum 2d elements as much as possible. Most 2d groups inlcude 2d window, door, membrane, flashing & etc. It's good the group does not necessarily increase model size.
wall section sample
Fri, Jan 20, 2006 at 5:38:46 PM
section tags for broken wall sections
Fri, Dec 7, 2007 at 10:57:25 AM
RAC 2009 - detail groups and section detail blow-ups
Fri, Mar 26, 2010 at 8:50:53 AM
The option to create Wall section not showing up, only building section.
Wed, Jan 23, 2013 at 3:16:46 PM
Wall Section won't show in both plan and building section
Wed, Jan 29, 2014 at 6:52:25 AM
Page generation time: 1.0584
