Forums >> Revit Structure >> Technical Support >> Pouring A Slab on A Complex Surface
Tue, Oct 6, 2015 at 1:49:51 PM | Pouring A Slab on A Complex Surface
KraigZ
So I am working on a Chapel, and we are designing the roof for a Nave. We need to pour an 8" slab over complex curved surfaces so that stone can be seccured to it. I am having a hard time getting this done in revit. I suppose it could be a different type of component, but i need to show an 8" surface over the top of the surface shown. (see picture) I appreciate your help. If you can help me accomplish this, you will truely be a revit master.
Tue, Oct 6, 2015 at 2:30:15 PM | Pouring A Slab on A Complex Surface
Maybe you got this backwards... decide how first before you model.  The Concrete could be a simple layer of a roof.
Thu, Oct 8, 2015 at 4:09:43 PM | Pouring A Slab on A Complex Surface
KraigZ
That wont work, I think because it is to complex. Any other ideas befor i declare this impossible?
Thu, Oct 8, 2015 at 4:25:31 PM | Pouring A Slab on A Complex Surface
Absolutly not too complex unless you are not telling us something.  If you modeled those brick like elements then that is a big mistake.
Tue, Oct 13, 2015 at 3:20:17 AM | Pouring A Slab on A Complex Surface
tahaij
you can use roof by profile, you will get two roof objects for each galley.
Tue, Oct 13, 2015 at 5:44:45 PM | Pouring A Slab on A Complex Surface
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Additionally, you could do a roof by picking the face of a mass being used to drive the overall shapes of the vaults. The process is important like WWHub said. Based on that, there many ways you could do this.
Wed, Oct 14, 2015 at 12:26:32 PM | Pouring A Slab on A Complex Surface
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
send capture of existing roof details, including Edit Assembly of Roof Properties
Schedule concrete volume (including column, slab & beam) by workset
Thu, Oct 28, 2010 at 8:04:52 AM
Model lines not showing up on slab surface
Sun, May 1, 2016 at 8:30:20 AM
Can Floor Slab Edge Material be different?
Thu, Dec 1, 2011 at 3:44:57 PM
Site Materials in 3d views with a complex site
Mon, Jul 3, 2006 at 4:32:18 PM
Topographic surface linked vs. in model
Tue, Mar 19, 2013 at 6:15:37 PM
Page generation time: 0.9607
