19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Nested Revit Families upside down
0 Posts No Rating |
I am inserting nested massing models into a massing file. When I insert Revit's standard Gable on Level 1 it comes in fine, but whenever I create new levels and try to place on work plane for the new level the nested Gable mass inserts upside down. Any help would be much appreciated. I have attached the file.
In the rowhomes family, select gable family and click ‘flip work plane’ - the icon will display when you click on the gable family (dbl arrow with rhombus), or in the gable family, check 'always verical' and uncheck ‘work plane-based’ in the properties. The 2nd option let you choose between placement on a face or a work plane. In your case, the gable family will be always work plane based, so when placing in 3D view, pay attention to the option bar, it will show you what plane it’ll be placed on.
0 Posts No Rating |
Thanks for the help
Locking nested families? |
Wed, Aug 27, 2008 at 12:23:09 PM
13
nested families do not cut |
Thu, Jan 14, 2010 at 11:44:55 AM
Door swings with nested families |
Fri, Sep 18, 2009 at 1:41:24 PM
Hiding nested families in a project |
Thu, Jan 14, 2010 at 10:21:37 AM
turning on/off nested families in host family in different views in project. |
Fri, Aug 7, 2009 at 11:11:32 AM
