Forums >> General Discussion >> Revit Project Management >> Central File Path on a local file
Mon, Oct 5, 2015 at 12:33:48 AM | Central File Path on a local file
janonliu
Does anyone know how to add a central file path label to a titlesheet. Adding the file Path parameter only adds the local file location.
I been searching for ages and couldn't find a way of doing this, other than opening the central file and printing directly from there?
Surely there must be a way of doing this?
Having a local file path is pretty useless when working on a central model.
Sat, Oct 24, 2015 at 10:21:20 AM | Central File Path on a local file
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
In your sheet family, create a label and use the "file path" parameter under the sheets category.
CENTRAL FILE PATH NOT FOUND HELP HELP!!!
Sun, Feb 22, 2009 at 12:35:49 PM
can't view file properties - central path
Fri, Aug 21, 2009 at 2:34:53 PM
Plot stamp: Set file-path to Central
Tue, Jun 7, 2016 at 8:33:00 AM
Can not create local file from Central
Tue, Mar 6, 2012 at 11:57:26 AM
Central/Local File Synchronizing Issue
Sun, Jun 23, 2013 at 2:33:20 PM
Page generation time: 1.1817
